Ae86 3tc swap exhaust solutions
Swapped r&p into my corolla and looking to either fab up a header chop a 4age header and make it work or using the stock manifold.
Lets see those headers
Re: Ae86 3tc swap exhaust solutions
Custom made 3TC AE86 hi rise Header bro!
PS it is in a starlet but it fits AE86 perfectly
Race header
Race header
Also i got this one that is made the easy way with a AE86 Stainless header,
Did you slot the mounts on the crossmember?
What you mean the ones on the crossmember itself? nope!kid_te72 wrote:Did you slot the mounts on the crossmember?
Why?
Cause thats how people usually make 3t fit in an ae86 i made up some plates and used them to scoot the engine forward about 3/4"
Actually i mount the tranny where it goes and with the engine attached to the tranny i weld little extensions to the factory engine bracket to use the factory crossmember brackets and 3tc mounts it works perfect every time and the engine is in the right place all the time!
Sounds like a good method I have a 6 speed behind my 3t so lining everything up was weird I did a lousy job honestly haha
A 6 Speed from what?kid_te72 wrote:Sounds like a good method I have a 6 speed behind my 3t so lining everything up was weird I did a lousy job honestly haha
Many ways to do it. Most Hawaii guys use the TE72 engine x-member, straight bolt up, no cutting or welding.kid_te72 wrote:Cause thats how people usually make 3t fit in an ae86 i made up some plates and used them to scoot the engine forward about 3/4"
