Alternator wiring.
Re: Alternator wiring.
Great, thanks for your help.
Next up will be my distributor wiring...
Post the result so we can learn to
Sure anything you need to know post them up we will be glad to help
I will most definitely post the results. Probably with in a few weeks.
If I no longer have an instrument cluster, can I wire the (L) pin to an aftermarket volt meter?
Volt meter meassure the overall voltagegotae86 wrote:If I no longer have an instrument cluster, can I wire the (L) pin to an aftermarket volt meter?
The alternator need this low amp L 12v to trigger the voltage regulator so it start charging
I thought L meant light which meant a light on the dash meaning the charge system light in the gauge cluster.
Check the diagram you will notice the L wire how it run true the circuit
- Attachments
- 2014-05-14 23.14.10.jpg (2.37 MiB) Viewed 9917 times
Thanks for clearing that up.
Always around to help brogotae86 wrote:Thanks for clearing that up.
