How to tell which starter I have
superhead91
Post by superhead91 »
I've been doing some searching, but haven't found anything that helps me figure out which one I have. I'm trying to figure out which T50 bellhousing/flexplate I need, so I need to know which size starter I have. Any easy way to tell?
Re: How to tell which starter I have
Can you post an picture
T50 is manual so it doesn't use any flexplate ! you have an big an small starter correct
superhead91
Here's a crappy pic. The guy I'm buying the T-50 bellhousing from thinks it's the large starter.
73te27
Post by 73te27 »
71-74 is non gear reduction large, bottom bolt from front. 75-80 is small and 81/82 is large gear reduction, both bolts from back.
