81 corolla rear brake disc conversion
What is the best car to get the parts from? Forget the ae86 I will never find those parts. I know people have used Supra, Mustangs and rx7. If anybody has done this and maybe have pics, I would like to hear from you.
Re: 81 corolla rear brake disc conversion
You could use a 8.8 posi out of a Ford Explorer. The pumpkin is offset so you will need two passenger side axles (I think that's the correct side) and cut the driver side to the correct length.
mustang will work, theres a million of them and really cheap, if its a disc brake conversion only you can make the datsun stuff work easy also.baldo wrote:What is the best car to get the parts from? Forget the ae86 I will never find those parts. I know people have used Supra, Mustangs and rx7. If anybody has done this and maybe have pics, I would like to hear from you.
My brother designed brackets to install the 200sx brakes to the corolla rearend and there are many similar set up soon dwarf car websites.
http://www.peterdmotorsports.com/hubs---rotors.html
