duel weber 40 starting issue
Posted: Thu Mar 06, 2014 2:24 pm
by kazeron
Re: duel weber 40 starting issue
Posted: Fri Mar 07, 2014 1:37 am
by baldo
I know for a fact that the carb is delivering fuel, i took them off and checked all my fuel delivery and the carbs are shooting fuel into the manifold. I will be honest, I know nothing of carbs. :? By checking the fuel delivery, do you mean the pump or the actual carb? Enough gas has to be in the carb for it to run. Is the fuel at the same level on both? It would not start pressing the pedal either?
About "prestart tune"? Maybe that would be changing the jets that you think you need before putting them on? What does that mean? :lol: When you say all your jets are factory, that means the carbs are new? Venturis might be too big? You picked the worst type of carbs to experiment with. You should of started with 32/36, get used to play with that. Then move up when you understand how they work. It could be lots of things, jets, venturi, pump, gas not going in the carb, new, used, vacuum, gaskets, connected everything back.......... Anybody you know running them?
Posted: Sat Mar 08, 2014 10:25 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
