Page 1 of 2
engine removal issue. 3tc Ae86
Posted: Thu Feb 27, 2014 10:59 pm
by hachicoupe
hi guys, I am currently having an issue removing my 3TC from my car. I have disconnected it from the transmission it is a manual transmission and it will not come out of the engine bay it seems like its getting hung up. The only other thing I can think of is to bolt it back to the transmission then take it out, but it will not line back up with the transmission bolt into place. Any help is much appreciated. I need it out to remove my crankshaft. I've been trying to remove it with a hoist for 3 days and it just wont come out :(
Any tips? Please help.
Re: engine removal issue. 3tc Ae86
Posted: Fri Feb 28, 2014 1:21 am
by 73GTV
http://members.iinet.com.au/~stepho/manuals/Toyota/
Download the manual you need and you can find the problem.
Posted: Fri Feb 28, 2014 2:25 am
by hachicoupe
73GTV wrote:http://members.iinet.com.au/~stepho/manuals/Toyota/
I dont understand how those help?? I know how to service the engine once its removed. But the engine just won't come out... I can see the splines on the trans, and they are totally disconnected from the engine. It just wont come out. I think I just need to drop the trans from the bottom of the car...
I just dont understand why I cant get it out :/
Posted: Fri Feb 28, 2014 4:20 am
by toyotero2dend
Check if fuel line still attach ,,,check the ground cable on back of the engine,,check the flex plate might have 2small bolts on the bottom holding the trans.
Posted: Fri Feb 28, 2014 5:16 am
by NME308
Maybe the differential has not been disconnected from the half shafts or the handbrake is on?
Posted: Fri Feb 28, 2014 6:22 am
by hachicoupe
NME308 wrote:Maybe the differential has not been disconnected from the half shafts or the handbrake is on?
Wait... I don't understand how these would affect anything...?
It is fully un bolted... and all lines/ cables are disconnected.
Posted: Fri Feb 28, 2014 7:24 am
by skellington
If I were you, i would take out the engine and trans all at once. I have done it like this every time without issues. Just keep an eye out for that pesky engine ground cable that gets me every time. If you leave the manual trans in the car, you have to slide the spline all the way out to let it be free. To do this you will have to side your engine forward a few inches to the front of the engine bay. i have never done this. Hope you figure this out.
Posted: Fri Feb 28, 2014 11:31 am
Are you sure you didn't forgot the tinny starter plate bolts ? Or the tranny pillot shaft is jam in the bearing ?
Posted: Fri Feb 28, 2014 12:44 pm
This is happening cuz i do mess up on that too more than a year ago :lol: :lol: :lol: :lol: :lol: :lol:
Make sure you got all the fuses in the fuse box installed or it wont go out! :roll: :roll: :roll: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Posted: Fri Feb 28, 2014 3:02 pm
by hachicoupe
BOBLOOK wrote:Are you sure you didn't forgot the tinny starter plate bolts ? Or the tranny pillot shaft is jam in the bearing ?
Everything is unbolted and apart. 100% sure. Basically I think its just stuck on the last bit of the pilot shaft. I am going to drop the trans out from the bottom and pull the engine out then put it back together before it goes back in.
