1972 te27 exhaust?
Posted: Fri Feb 14, 2014 4:51 am
by totorote27
does anybody know if a 1972 corolla (te27) came factory with a catalytic converter?
Re: 1972 te27 exhaust?
Posted: Fri Feb 14, 2014 6:00 am
by docta22
I used to own a 74 sprinter. No catalytic converters were installed as far as I know.
According to what I found online "Catalytic converters were first widely introduced in American production cars in 1975 due to EPA regulations on toxic reductions. The United States Clean Air Act required a 75% decrease in emissions in all new model vehicles after 1975."
Hope this helps.
Posted: Fri Feb 14, 2014 6:34 am
by skellington
No cat? I'm going to have to take a look under my 74 te27. I do know that it has a smog pump, but California is special when it comes to emissions. I know that my 74 civic has no cat.
Posted: Fri Feb 14, 2014 5:55 pm
by totorote27
this is the exhaust that came off of my 72 te27. the bigger one is the muffler however im not to sure what the smaller chamber is. Can anyone clarify what it is?
Posted: Fri Feb 14, 2014 9:54 pm
by docta22
Thats a central resonator friend. It prevents unwanted vibrations and booming in the cabin of the car caused by exhaust pulses.
Resonators are usually double walled cylinders packed with a sound dampening material or even baffled.
Catalytic converters are usually covered in heat shields as they operate under high temperatures.
hope this helps.
Posted: Fri Feb 14, 2014 10:42 pm
by totorote27
thanks for the info. very helpful. the reason i want to know is because the series i am planning on racing in requires that if the car came with a cat then it is necessary to use one. if no cat was installed from the factory then it is not necessary. i didnt think it came with one i just wanted to get more confirmation thanks
Posted: Wed Feb 19, 2014 4:17 am
by VinceG2
Yup, that's a resonator. The first usage of a catalytic converter was for the 1975 TE31 Corollas in California (TE31s outside california didn't have them). Pre-75 has no cat.
