82 TE72 Altezza 3SGE BEAMS 6spd swap work in progress
Dominicaneddy here from Old School Toyota Car Club of Bridgeport CT
Its been awhile since my last build (1972 Toyota Turbo 2rz Carina )
Now onto the next build - 1982 Toyota Corolla shell picked it up and taking it home
Altezza Blacktop BEAMS 3SGE swap with 6speed transmission installed.
Tubular cross member
Oil pan shaved and fly wheel dust cover fabbed
motor is in nice and straight
Tranny crossmember
Engine crossmember mounts
Waterneck fabbed foward
Celica supra lsd posi rear end getting ready to be swapped in
Manifold fabbed as well it clears everything
Adjustable lateral bar fabbed for the rear
Towed home from fab shop
She sits waiting for step 2
Tranny crossmember
Re: 82 TE72 Altezza 3SGE BEAMS 6spd swap work in progress
Beams in a TE72 and there is a step 2??
This will be good!
This will be good!
- skellington
YES!!! I love this thread already. I want to do a beams with 6 speed swap just like this. If you can, please include the little details. Can't wait for step 2.
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
Thank you
I will be using the factory ECU & the factory harness has been sent to Tweak'd performance to be done into a univeral install.
A 97 2wd tacoma 1 piece drive shaft is getting the yoke fabbed for the celica rear.
ordering an alluminum 82 corolla radiator
NEED a w57 or w58 speedometer gear drive (part the speedo cable hooks up to on the tranny)
Considering all the info on these motors just going to keep it all stock its perfect for just to cruise with, I'm trying to decide on wether to have AC or not.
Where do you guys get the time to work on rides nice Eddy
Very nice project eddy!,keep up the good work
Good swap info any plans for brake caliper upgrades
only on weekends also we are not just a club but more like family and always helping each other no matter what time or day it isBOBLOOK wrote:Where do you guys get the time to work on rides nice Eddy
thank youtoyotero2dend wrote:Very nice project eddy!,keep up the good work
no just going to keep it stock but once car is up and running and painted possibly might go the rx7 caliper routecarboyRolla wrote:Good swap info any plans for brake caliper upgrades
