What I am referring to is the bolt hole visible in the picture above on the girdle between each pair of studs. There is a bolt & lock nut in each one to provide extra support to the center of each cast main cap under stress. The engine builder had nipped each of these bolts up tight against the cap & that is what caused the bearings to touch the crank top & bottom.
