la otra 3tc starlet
mallito1.8
Re: la otra 3tc starlet
Post by mallito1.8 »
NME308 wrote:
mallito1.8 wrote:the idiot used a sander to shave my head and was not flat so that leads to the root of failure
Did you just say what I think you just said???
mallito1.8 wrote:...used a sander to shave my head...
Well I'm glad to see you have decided to do the reassembly yourself! Even if you don't have a clue you surely can't do worse that your idiot friend!!! :shock:
I hope it all goes well for you from here. :)
actually my friend did the putting together but a local machinist messed up my head wich he went out of business no wonder
Post by Toyota1515 »
Mallito if you are using a copper head gasket u need to use hi temp RTV in order to seal the water passages, plus as far as i know your head must have a land to receive the O-ring from the block so it can achieve a proper sealed chamber and the gasket itself lands flat against the block and head with proper clamping force, just saying, paint the head with die blue and torque it down without gasket so it marks exactly where the o rings are around each cylinder then take it to the machine shop to cut the groove.
Those copper gasket work best if you-re not running water true the block ! Head welded running water in the front to the back.
Sorry to hear mallito hope you fix it soon !
O-ringed Casaña racing block
mallito1.8
BOBLOOK wrote:O-ringed Casaña racing block
Yea pretty much my block looks like that but I don't want to seal the water jackets cause my car is not full blown race car it's a weekend toy but not for the streets. Thanks guys
Oh okay why not running cosmetic gasket
I remember Eville was running half filled block on E85 so far i knew he didn't had cooling issue
mallito1.8
I was told you can't run cometic gaskets with a o ring block
mallito1.8 wrote:I was told you can't run cometic gaskets with a o ring block
No you can't !
am the one talking nonsense i didn't put attention to your picture
Your block is o-ringed
hemilove
Post by hemilove »
wow looks nice how much was the cutting in the block to get it done?
mallito1.8
No you can't !
Oooo ring. Hahah
