Page 5 of 8
Re: TE21/S2000 Swap
Posted: Mon Feb 16, 2015 2:20 pm
by spiceisler
So far so good. Looking forward to more on this.
Re: TE21/S2000 Swap
Posted: Fri Mar 27, 2015 8:48 pm
by f20c1981te72
Sick work so far working on my te72/s2k swap myself
Re: TE21/S2000 Swap
Posted: Thu Apr 02, 2015 9:08 pm
by phaze2henry
So dope!
Re: TE21/S2000 Swap
Posted: Fri Apr 03, 2015 2:46 pm
by Rolap7
Re: TE21/S2000 Swap
Posted: Fri Apr 03, 2015 2:47 pm
by Rolap7
f20c1981te72 wrote:Sick work so far working on my te72/s2k swap myself
Nice! share some pics
Re: TE21/S2000 Swap
Posted: Fri Apr 03, 2015 2:51 pm
by Rolap7
phaze2henry wrote:So dope!
thanks Henry! I'm a fan of your build sir *salute*
Re: TE21/S2000 Swap
Posted: Fri Apr 03, 2015 3:01 pm
by Rolap7
Re: TE21/S2000 Swap
Posted: Sun Apr 19, 2015 12:28 pm
by Rolap7
Got the steering column put together:
Re: TE21/S2000 Swap
Posted: Sun Apr 19, 2015 12:38 pm
by Rolap7
Since I converted to ae86 rear end/disk brakes, i needed to modify the emergency brake cabling
The finding a front cable with the correct length saved me a lot of work. Hopefully this will help others who are going with ae86 rear end.
Since the s2000 6 speed transmission is so long, I needed to shorten the ebrake handle for clearance:
Sorry for the upside down pic. I'll add some finished shots later.
The rear cables are just two ae86 driver side cables (if I recall correctly) i'll check the box and confirm.
Re: TE21/S2000 Swap
Posted: Thu Apr 23, 2015 1:53 pm
by maxdout
Rolap,
so which cable did you end up using for the front cable.
