TATE QUIETO 1.8 >2016,,Mission accomplish EFI + Boost
Re: TATE QUIETO
Well if I was you I would go in a plenum if it was efi but are you sure its a good vacume sorce due to the butterfly blades being behind the boost what if you have the blades closed will you still recive vacume or will it be positive pressure hopefully I didn't get you confused bc carbs are not my thing the hilux was more easy than you think bro lol
Re: TATE QUIETO
Carlos there is always vacuum there at idle ,but at time of acceleration the vacuum is less to zero
the new bonnet fits like a glove
1"difference on the height
(pic.s) first is the new one second the old one
Re: TATE QUIETO
thanks Carlos
hey I see you have the w series tranny ,,you can weld the starter hump on the left side & the other piece on the right side use the back plate of the engine for reference
if the shifter is too far to the front do what I did with the supra shifter plate
Re: TATE QUIETO
Tpr motorsports cut the bellhousing and it fit like a glove the shifter is in the same location my man I had thought I was gunna have to chop it but didn't have to
Re: TATE QUIETO
so you moved the engine back a few inches? for the shifter to be in the same location??
- mallito1.8
Re: TATE QUIETO
hey I know how you can make that bonnet fit. put a rotary engine
oops my bad.. looking good junior I wanna hear it soon it makes you feel very good once you hear it on I can tell you that. by the way I should get my computer back Monday so then ill post a video. later bro suerte
Re: TATE QUIETO
I'm hoping on start it soon mallito ,,, and yea let's hear the starlet roar (<;
Re: TATE QUIETO
- skellington
Re: TATE QUIETO
Sweet car! Wish I had that in my engine bay.
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
