Te27 1974 STARTUP ON PG 7
- skellington
Re: Te27 1974
Very nice. This inspires me to work on my TE-27. I noticed that you used ebay coilovers. If the spring rate is around 320lbs. then you have the same set up that I have on my TE31. It will ride stock height, but will be nice and firm. Looking forward to more progress.
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
Re: Te27 1974
skellington,
It shouldn't ride stock height cause I used a short stroke shocks, plus I notice the ebay spring is almost the same as the qa1 7-250 springs that summit sells. That qa1 spring I brought for my TE28. Now the ebay one is not the Best quality but it does the job...lol
Re: Te27 1974
skellington
I just read your post on your TE31 suspension....hmm now you got me worrying..lol am I gonna end up with stock height.....Also nice score on the TE27 you got.
- skellington
Re: Te27 1974
Sorry for the long ramble, but I hope it helps.
1974 TE27 TWINS!
Re: Te27 1974
quick update, flares are on outside is almost all back together.....Yes I know its a 4x4 right now. need to lower the back and without the engine I don't know how low I sit in the front.
- skellington
Re: Te27 1974
Wow. that thing is looking good.
1974 TE27 TWINS!
Re: Te27 1974
Here is with better lighting
Re: Te27 1974
Thanks everyone for the compliments. Well time to start working on the rear suspension and the undercoating. Going with lowering blocks and camaro shocks
and factory 8bolt rearend for now...also have to rip out this old exhaust. And need to scrape all this old undercoating
