Toyota1515 wrote:No i didnt mean Supertech, i mean any Stainless Steel valves, that will last more and dont crap on your expensive head work and cost you catastrophic and unrepairable damage just cuz you cheap out in such an important component of the head, i have seen OEM 4age valve that broke and do all the before mentioned, take it as an advise,
Odd... I've not yet had a valve failure....
There are not many companies making valves for the 4AG.... that's why I asked you if you were talking about Supertech. Do you have a company in mind??
oldeskewltoy wrote:So with the ports nearly finished... I proceed to the chamber work. Basic, or minimum deshrouding to start....
but more will be required...
I wasn't sure how much... after all... the clients valves were not going to be used, I had picked through my old valves for a decent set. So "new" valves, and had them ground, along with the 3 angle grind.... after all of that....
Chamber volumes were....
35cc, 35.2cc, 35.2cc, 35.1cc (based on beginning meniscus levels)
All in all not too bad, well within acceptable tolerance... but I worked #1 a bit more then the other three, I'll have finished chamber volumes by Monday...
Now here is the progression of chamber #2....
More to come..........
