Page 3 of 5
Re: MSD instalation guide
Posted: Thu Apr 02, 2015 8:48 pm
by Escoriasza
Okay..what wires connect to the red and white coming off of the distributer?
Posted: Thu Apr 02, 2015 9:22 pm
Posted: Fri Apr 03, 2015 12:05 am
by Escoriasza
dizzy means distributor right? I'm pretty sure I did like that then I read online in this threat that I have to not use the green and purple and use the white wire instead?
Posted: Fri Apr 03, 2015 5:40 am
dizzy means distributor right yes
You can use both option ! if you do it as per the notice it should work
Was the msd working before you purchase it
Posted: Fri Apr 03, 2015 5:44 am
http://www.street-fire.com/pdf/5520.pdf
Where does the red wire go switched 12V ??
Posted: Fri Apr 03, 2015 11:29 am
by Escoriasza
Okay thank you I'll try both ways. Yes everything was new when installed. I hear the purple and green wire are used only if I have an electronic dizzy which I have a points dizzy so I'm suppose to use the white wire but I'll try this way again.
Posted: Fri Apr 03, 2015 11:31 am
by Escoriasza
It's going to a switch that you have to turn on before turning the key so the engine can get spark and turn on. If the switch isn't on the the engine just turns over without getting any spark.
Posted: Fri Apr 03, 2015 2:24 pm
Escoriasza wrote:Okay thank you I'll try both ways. Yes everything was new when installed. I hear the purple and green wire are used only if I have an electronic dizzy which I have a points dizzy so I'm suppose to use the white wire but I'll try this way again.
Your installation is electronic dizzy if you not sure open the dizzy cap and show whats below
Posted: Fri Apr 03, 2015 9:46 pm
by Escoriasza
I have a stock 3tc dizzy from an 82 corolla. I read in the previous posts on this threat that means I have points and not electronic?
Posted: Sat Apr 04, 2015 1:29 am
by Escoriasza
Got everything working great..thank you so much sir!!
