Ye Finland, how much do you want for those? Are you in facebook?BOBLOOK wrote:€ 11,00 (12$ USD chipeast without trace ! 18€ (20$ USD) with traceBOBLOOK wrote:Finland ?
Got it.BOBLOOK wrote:sold plus shipping
After the track day i,ve thinked to order new suspension kit, cheap but still. http://www.ebay.com/itm/TA-TECHNIX-PREM ... fresh=true
easy to fit in these and can adjust the height and spring preload.
Yesterday and today after work
And suprise from the gearbox
So it is going to stand thru the winter, trying to get it boosted. There is still summer left but there was problems with stock carb and headcasket started leaking oil and clutch cylinders started to leak so i decided to take it apart...
Some "new" parts.
Arp for the rods
Those injectors where to long so had to make spacer for fuelrail.
Old front suspension is sold and planning to fit Nissan s13 adjustable front suspension with bigger brakes.
Arp for the rods
T brackets welded on Ke crossmember, and block is now in machine shop. 85mm-->88mm and deck surfase straightening.
