1979 Datsun 210 SR20 Dual Side draft Carb N/A!
Mazota TE51
Re: 1979 Datsun 210 SR20 Dual Side draft Carb N/A!
Well let me see its not a Toyota and is not going to have a Toyota heart he must be lost..
I like that body style a lot nice find, my dad used to have one and he couldn't kill it. The thing had over 300k. Please keep us posted on this project.
here is what i was trying to get from Japan!
Ok here is somethin i do last nighet when imsomnia attacks,
Went downstaresand start mocking up the engine tranny combo,
If you are familiar with Nissan u must know SR20 block castings are different from FWD to RWD
But u can use the FWD one in RWD with some modifications but you cant do the other way around!
Here is what u need to trim from the FWD block to make it fit on the RWD tranny,,,
You need to trim all that to get the RWD starter on its place,
Then in order to atach the tranny on that side a heavy duty bracket need to be fabricated, and that bracket is bolted to the side of the block and goes back to the tranny bellhousing under the starter, this bracket must be minimum 3/8 thick steel or 1/2 inch aluminum,
It will be cool and super strong, this way any SR20 block could be used and i dont have to be obligated to use the ABUSED RWD blocks only!
Pss
By the way those mods is only on the starter side cuz the other side it a prfect fit!
Pss
Just in case you guys ask or worried about the amount of material to be removed from the block,,,
Is not that much for real, the RWD casting do not have the starter ring whatsoever and the only difference is the lower ear for bellhousing attachment is in a lower position, thats it, i am just replacing the lower ear with a fabricated bracket that bolts to the engine block next to the motor mount bracket and maybe 3 or 4 oil pan bolts all together,
I do drill one hole on the tranny bell to acomodate the top right hand bolt and use a spacer betwine the tranny bell and the engine cuz the bell is hollow there,
But here is a rugh sketch of what that bracket will look like!
By the way the top bracket is not necesary but i just trow it out there just in case someone ask!
Good to know, looks like a lot of work though lol keep the good work up
Nahh not that much, but once you do it you can use either of the 2 castings, and trust me these ones are less abused than the RWD ones!lopez286 wrote:Good to know, looks like a lot of work though lol keep the good work up
Wat Ecu you gone use to controle the itb ?
None, itb in the pictures are just for the photo shine, it will be carburated with dual side draft solex 40's!BOBLOOK wrote:Wat Ecu you gone use to controle the itb ?
