Re: OST-029: California here I come......
Posted: Fri Jan 30, 2015 1:38 am
from another forum wrote:Looks real good especially the short turns and the chambers.
exhaust #1
all the chambers
More to come........
Welcome To The New Home of 3TC Follow Use On Social Media https://www.facebook.com/groups/3tcgarage/
http://3tcgarage.com/
After the cut, with the valves fitted... waiting for checking chamber volumes....oldeskewltoy wrote:
Really? which Webs? My AE86 used the Web 294 grind and they passed, albeit with a new OEM type cat, but they passed. And I'm pretty sure OST-019 passed using a mild cam, but it needed a bit of ignition timing tweaks to pass.from another forum wrote:Since this head is coming here to Cali. Is the customer going to do any kind of camshaft or just use the stockers? I'd be curious I know that my web cams in my N/A engine wouldn't pass smog.
oldeskewltoy wrote: "Volumes" to come........
They shouldn't....... Nothing I've done is actually drastic. For the most part I'm just improving the original casting by port matching the seats-bowls-ports to more closely match the original design. The surface machining of .018" is not beyond the normal range. A multi angle valve job is not beyond typical. The slightly raised compression will not hurt either.BOBLOOK wrote:California ? would those mod affect the ca emission drama on there ?
First apologies... the more common, and in this case correct term is actually "tumble generators"from another forum wrote:
What are swirl generators? I can see everything else you pointed out thanks.
oldeskewltoy wrote:So last "quiz" on this head....
What's up?
more to come.....
