Re: complete 4ye long block and 45 webers fs with pics nj
Posted: Sat Jun 21, 2014 5:31 am
				ok material has to be added to the head so the head seals to the block on the lifter side of the motor, two water holes have to be welded shut and one hole needs to be welded the drilled and tapped for oil to get to the head. these pics should show you what has to be done. enjoy i was planning on doing this but im getting out the car game for a while
the two water galley hole in between 1-2 and 3-4 are welded shut. also the last hole on the left is the the one that gets welded,drilled and tapped for an oil line like a turbo feed
