the two water galley hole in between 1-2 and 3-4 are welded shut. also the last hole on the left is the the one that gets welded,drilled and tapped for an oil line like a turbo feed
Oh okay thank for the inforidin4life wrote:The 4y block is wider and will leak oil out the side if not welded.
