F/S Turbo Log 3tc Manifold
This here is an oldie but goodly log manifold, made by your truly using 3/8 flange and 1.62 inner diameter carbon steel pipe with a 38mm wastegate. this is not the one you're going to receive as i will make it to your specs. if you have a t3 or a t4 turbo just let me know. 200 shipped.
Re: F/S Turbo Log 3tc Manifold
Mike... I have a te27 that needs a turbo manifold. I plan to run a small T3/T4 turbo internal wastegate and need the flange top mounted by the #1 and #2 cylinder. Shipped to 94561?
Any info bro...
Thanks
Theo
Hit me up major8roundSS@comcast.net
Any info bro...
Thanks
Theo
I can get it done, MikeTizzon wrote:Mike... I have a te27 that needs a turbo manifold. I plan to run a small T3/T4 turbo internal wastegate and need the flange top mounted by the #1 and #2 cylinder. Shipped to 94561?
Any info bro...
Thanks
Theo
Good stuff again!!
always, trying to keep it in a budget....slaus wrote:Good stuff again!!
GOOD TO GO PEOPLE!!!
