Post question & Frequently common parts that you find that fit but weren't supposed to-include the parts numbers if where possible.
Moderators: BOBLOOK , AE25 , pufito18
TOYOTA_LOVER
Posts: 4 Joined: Fri Jun 28, 2013 4:04 am
Post
by TOYOTA_LOVER » Wed Jul 24, 2013 1:39 am
I have a 6a hooked up to my 3tc and I get no spark. It ran fine before doing msd upgrade msd box gets power (cuz power light turns on) I have the purple n green wires ran right to dist. not using white wire n gray is to the tach. Any ideas on why no start
Posts: 2339 Joined: Wed Jun 19, 2013 7:32 pm
Post
by BOBLOOK » Wed Jul 24, 2013 8:38 pm
Use the white wire on a previous install the green purple failed after installation
TOYOTA_LOVER
Post
by TOYOTA_LOVER » Thu Jul 25, 2013 4:43 pm
So connect the white to pos+ of dist. then what to do about no power to coil
Post
by BOBLOOK » Thu Jul 25, 2013 9:06 pm
TOYOTA_LOVER wrote: So connect the white to pos+ of dist. then what to do about no power to coil
You need to hook only the
black and orange on the coil
The msd will take care of the coil power itself
TOYOTA_LOVER
Post
by TOYOTA_LOVER » Thu Jul 25, 2013 11:18 pm
I get no power to coil from msd only power out I get is from white
think it is bad msd box I really do THANK YOU FOR YOUR HELP
Post
by BOBLOOK » Fri Jul 26, 2013 10:32 pm
TOYOTA_LOVER wrote: I get no power to coil from msd only power out I get is from white
When you said no power to the coil do you mean no 12V ??
Did you crank the engine to check for spark usually those msd don't burn so easy ?
Can you post the installation picture the way you wired ??
TOYOTA_LOVER
Post
by TOYOTA_LOVER » Thu Aug 01, 2013 7:24 pm
I have from msd box heavy red to bat. heavy black to chassis ground orange /black to coil grey to tach green/purple to distributer white wire not used but gives power out and red ignition The box turns on as seen by the power light. car cranks no spark u said use white wire to where?????
Admin
Site Admin
Posts: 80 Joined: Fri Jun 14, 2013 10:06 pm
Post
by Admin » Sun Aug 25, 2013 8:22 pm
Heavy red = Plus +
Heavy black = ground
Red = 12v ignition switched
Orange = plus + coil positive
Back = negative coil
The tach wire goes to the input of the msd
Check it the msd is set for 4 cylinder
The green and purple is for the magnetic pickup distributer !
Or The with wire to the negative of the distributer magnetic pickup
