I have bolt in those new ones from Thai and yes they fit, as Toyotero2dend said u may need to work the wires a little bit depending on the year but the actual assembly fit just perfect!man of GOD wrote:see i just want to make sure that the ones from thailand fit my 82 2 doors sedantoyotero2dend wrote:Nope
ke70 tail lights , te72 ????????????
Re: ke70 tail lights , te72 ????????????
Toyota1515 wrote:I have bolt in those new ones from Thai and yes they fit, as Toyotero2dend said u may need to work the wires a little bit depending on the year but the actual assembly fit just perfect!man of GOD wrote:see i just want to make sure that the ones from thailand fit my 82 2 doors sedantoyotero2dend wrote:Nope
THANKS FOR THE INFORMATION ABOUT THE TAIL LIGHTS MEN , I APPRECIATE YOUR HELP
YES THEY WILL FIT. I HAVE A USA TE72 COROLLA IN TRINIDAD AND WE BASICALLY HAVE ONLY KE70's HERE. THE KE70 LIGHTS WILL WORK ON THE TE72 BUT YOU JUST HAVE TO WIRE IN FOR THE REAR FENDER SIDE MARKER LIGHTS. REAL SIMPLE
really this is good to know , since i dont know much about ke70 cars , all i know they look similar to the te 72 , i thank you guysslaus wrote:YES THEY WILL FIT. I HAVE A USA TE72 COROLLA IN TRINIDAD AND WE BASICALLY HAVE ONLY KE70's HERE. THE KE70 LIGHTS WILL WORK ON THE TE72 BUT YOU JUST HAVE TO WIRE IN FOR THE REAR FENDER SIDE MARKER LIGHTS. REAL SIMPLE
they fit but the wire harness from the 82/83 is going to be needed or you have to piece the wires in to have the lights work
80/81 use the same lights 82/83 are the same in jdm world they only have the ke70 but becareful when you see te71 or te72 because over there they are the liftbacks and sport coupes
+1
I create an Toyota Corolla E7 taillight interchangeable guide
rws1969 wrote:they fit but the wire harness from the 82/83 is going to be needed or you have to piece the wires in to have the lights work
I am looking for parts for a 19822 door sedan Toyota corolla. I need fenders for passenger and driver, shift boot, window regulators for both windows or 2 doors that have the windows working and headlight door left side with the signal light. If anyone can let me know where I can find these parts I would really appreciate it. I want to keep the car classic and fix it up. It runs beautiful, just needs some parts.
