Welcome. Try the PM option as that should notify the poster. Though not everyone has email notifications set on or check in often.
Best solution is the oem 3tgte bellhousing. If you can find one. Also the toyota 1G engines have the same bolt pattern but it puts the starter on exhaust side which makes it difficult for exhaust fitment.
An adaptor on the back of a t50 bell will add material between bell and box meaning the box sits even further back. If making mounts and driveshaft custom to suit then no worries.
W58 to 3tc adapter plate
