1980 TE72 3T-C
Post question & Frequently common parts that you find that fit but weren't supposed to-include the parts numbers if where possible.
Manny760
1980 TE72 3T-C
Post by Manny760 » Fri May 22, 2020 3:09 pm
Hello Everyone! I am new to 3tcgarage. I’m currently working on bringing a 1980 te72 station wagon back to life after sitting 10+ years. It is a pretty-much stock, California car, so it has the vacuum line octopus with all the never ending emission check valves. After spraying what felt like the entire engine looking for vacuum leaks I finally found it! I’ve got a leak at the Mixture Control Valve (located under the intake, closer to firewall with 2 vacuum lines coming out of it) It is stuck open at all times when it should only be open at decel. I have been unable to find a replacement part. If anyone has any station wagon parts or might know where I can find this emission part please share! Thank you!
Re: 1980 TE72 3T-C
Post by BOBLOOK » Mon May 25, 2020 9:12 am
Welcome on 3tc garage, you request for the parts can be better post in classified wanted section.
