T50 small parts needed
lotusman
Post by lotusman » Thu Jun 25, 2015 12:41 pm
Hi All, I am in desperate need of some (3) "washers/spring/shim" that are located between the bellbousing and the gearcase of T40/50 transmissions.
I bought a rebuilt tranny and these parts were left out and not available from Toyota.
The parts are 2 conical spring washers 68 and 52mm OD and a shim 41mm OD. the part #s are 90208-31001 and 90208-41002 for the spring washers and 90564-29147/shim.
I will buy a whole transmission if need be within 150 miles of Washington DC-this car has been apart from 1997 and just completed-except for these parts.
So Help if you can, please
Kevin Kearney
301 229 8820
lotusman1951@yahoo.com
toyotero2dend
Re: T50 small parts needed
Post by toyotero2dend » Fri Jun 26, 2015 1:28 am
this is my add if you interested
viewtopic.php?f=50&t=2513
enzee
Post by enzee » Thu Jul 02, 2015 5:27 am
Hi mate,
did you manage to find these parts?
I think I have what you are after. This is for the smaller bearing t50 with 20 spline count output shaft correct?
Aaron, NZ
lotusman wrote:Hi All, I am in desperate need of some (3) "washers/spring/shim" that are located between the bellbousing and the gearcase of T40/50 transmissions.
Kevin Kearney
301 229 8820
