Fuel gauge not working correctly
My fuel gauge doesn't read properly. When I put a full tank of gas the needle only goes to half on the gauge. So when the gauge says I have a 1/4 tank left it's really half. But it seems to be reading inconsistently all the time and it will stay on E or just slightly above even with a full tank or between that and 3/4 left. Should I just replace me sender in the tank or should I check other things before I do that?
-1992 Mazda MX-3 RS 2005-2012 *REST IN PIECES*
-2003.5 MAZDASPEED Protege #882 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 2014-2015 SOLD!
-1980 Toyota Corolla TE72 4-door sedan 2014-present
-2002 Lexus IS 300 2015-present
Re: Fuel gauge not working correctly
Forgot to mention I've removed the sending unit, cleaned the contacts and still doesn't read right. When I put the sender up to read a full tank the gauge still says half.
