Welcome To The New Home of 3TC
Post question & Frequently common parts that you find that fit but weren't supposed to-include the parts numbers if where possible.
12 posts Page 1 of 2
Shock insert used is topico or KYB Mr2 rear shocks insert used in toyota front struds
What car did these struts go to?
skellington wrote: What car did these struts go to?
This particulair strud was for te27 but you can use the same procedure for other models
for the TE72 which MR2 struts are used? The ones from the AW11 or SW20?
Admin wrote: Shock insert used is topico or KYB Mr2 rear shocks insert used in toyota front struds
the sw20 i have the partnr in my home data when i get back home i post the # here
What year MR2? and what model? I have a te31 (76) with 2 inch wide strut tubes that I want to do this to. I want to order the correct MR2 struts. It appears that you used the Ebay red and gold perches and springs. Do those spring rates work well? I cant find what rate they are and I am considering using them. -thanks
I do use the 1989 US specs Toyota Tercel struts insert, a little shorter than the SW20 ones!
Toyota1515 wrote: I do use the 1989 US specs Toyota Tercel struts insert, a little shorter than the SW20 ones!
How much " shorter are those ?
Are they also adjustable ?
cron
