Wilwood master for delete booster
The one stop topic for all the useful informations that gets lots in the mix.
Click her for the good stuff.
Post by BOBLOOK » Mon Sep 02, 2013 7:18 pm
Wilwood master for delete brake booster
I haven don''t this modification my self but the needed are simple the master and an custom aluminum adapter plate with the 4 bolt that attach to the existing booster hole and the pattern for the wilwood.
The rods need to modified a bit but isn't much work
http://www.summitracing.com/parts/wil-260-4893
punto8_369
Re: Wilwood master for delete booster
Post by punto8_369 » Tue Oct 01, 2013 12:38 am
Man I wish some that has done this would do a write up on it..... I really want to do this but don't want to mess anything up especially with brakes since I daily drive my car :?
Mazota TE51
Post by Mazota TE51 » Tue Oct 29, 2013 2:13 am
Has anyone done this mod on a street driven car and is the brake pedal significantly harder to make it unsafe for daily driven?
Post by BOBLOOK » Tue Oct 29, 2013 4:33 pm
Remove your booster vacuum hose and block it with something then go 100mph then brake :lol: :lol: you will feel the hardness !
Mazota TE51 wrote:Has anyone done this mod on a street driven car and is the brake pedal significantly harder to make it unsafe for daily driven?
Post by Toyota1515 » Wed Oct 30, 2013 1:33 am
Well is not bad at all IMO i like it better without the brake (lazy ass) Booster, cuz i can get better feedback from brakes, ;)
Mazota TE51
Post by Mazota TE51 » Fri Nov 01, 2013 1:06 am
Thanks guys. Boblook I am going to give it a try. I don't know about 100 but maybe 80 :lol:
Post by BOBLOOK » Fri Nov 01, 2013 7:57 pm
At you own risk :lol: :lol:
Mazota TE51 wrote:Thanks guys. Boblook I am going to give it a try. I don't know about 100 but maybe 80 :lol:
toyotero2dend
Post by toyotero2dend » Tue Dec 10, 2013 4:00 am
Mazota el pedal se pone como palo,you got,to press hard on it to stop but it does work,,one thing I noticed on my starlet I had 4 wheel disc brake and after I did this mod. The pedal wasn't that hard and the wagon would lock the wheels if I braked hard,,,but now on the .8 I have the same mod. But the rear brakes are drum and I notice it's harder to stop ,,hope this lil info helps
Post by BOBLOOK » Tue Dec 10, 2013 6:45 pm
The thing is when your drive your daily with booster your feeling use to it. As soon you drive you Toyo in the weekend the first corner you need to brake is very scary :lol: :lol: Don't tell me way :lol: 8-)
