Help Please!
casket77
Help Please!
Post by casket77 »
trying to wire my 82 starlet can someone help me identify which wires go were please.
casket77
Re: Help Please!
Post by casket77 »
Calling all Toyota top Dogs!!!!! lol
Mikealike
NME308's
Lopez286
etc etc etc someone has to know. ;)
Re: Help Please!
:roll: :roll:
The plug connectors shapes itself indicate where they goes in there counter-plug they where different shapes so you can't interconnect them while connecting
The longest is for the distributor the other are options tach/ and extr
See diagram
http://www.scribd.com/doc/217700/starle ... a-ig9-ig16
casket77
Re: Help Please!
Post by casket77 »
BOBLOOK wrote::roll: :roll:
See diagram
Well the reason I ask cause the coil and igniter are not from the car (82 starlet) and when I bought the car it had no engine or trans.so the plugs are different.
Re: Help Please!
You didn't said that so i though car most be stock so now you need an wire conversion 4age to 4k wiring ?
  • 1.
what engine was in the 82 stock
  • 2.
what engine is installed now ?
casket77
Re: Help Please!
Post by casket77 »
BOBLOOK wrote:You didn't said that so i though car most be stock so now you need an wire conversion 4age to 4k wiring ?
  • 1.
what engine was in the 82 stock 4KC
  • 2.
what engine is installed now ? 4AGE with single 40mm dellorto
Sorry Boblook I should of said so lol ;) wiring is not my thing as you can tell
Re: Help Please!
Okay i will need to look true the wire diagrams
The weber is mounted funny
Re: Help Please!
Post by Toyota1515 »
Thats an easy one, trow away the stock igniter and do a MSD 6al that will give u a REV limiter and a better spark that u will need for your 4AG plus only 2 wires from the dizzy will be used chose the right ones as i dont remember the colors, anyway it wont hurt it if connect the wrong one! on the dizzy i mean,
and as the MSD is mounted with a simple connection you should have no problem what so ever!
Re: Help Please!
Toyota1515 wrote:Thats an easy one, trow away the stock igniter and do a MSD 6al that will give u a REV limiter and a better spark that u will need for your 4AG plus only 2 wires from the dizzy will be used chose the right ones as i dont remember the colors, anyway it wont hurt it if connect the wrong one! on the dizzy i mean,
casket77
Re: Help Please!
Post by casket77 »
Thanks Guy's got it figured out! car fired right up but I'm going to have to get a MSD 6AL-2 like Juan said, stock 4age distributor does not advance the timing without the factory ecu.
