te27 rear end
te27 rear end
Planning on put down around 250 hp on the te27. What rear end would you guys use for that amount of power
Re: te27 rear end
71 to 77 hilux G code or 520/521 Datsun H190. Both will bolt on but need custom driveshafts and axles redrilled or different rims. Toyota is 1/2" wider then SR5 rear and stronger then Datsun but very heavy. Datsun is 1/2" narrower then SR5 rear and has aluminum chunk which makes it much lighter.
