Coil on plug VS MSD with distributor.
bryanhernandez3727
Post by bryanhernandez3727 » Thu Aug 20, 2015 1:55 am
What would be better set up for street modified 3tc with a 296 cam and race double valve spring and ported head. MSD 6A with 10mm spark plugs and maybe a locked distributor if thats a smart idea? or coil on plug ?
Corolla Kid
トヨタ
Re: Coil on plug VS MSD with distributor.
Post by BOBLOOK » Thu Aug 20, 2015 7:55 pm
Turbo or Na ?
MSD 6A with 10mm spark plugs The MSD6AL is better do the rev limiter
If Na no need for distributor locking
bryanhernandez3727
Post by bryanhernandez3727 » Fri Aug 21, 2015 3:54 pm
Yes i was thinking of putting a turbo.
Corolla Kid
トヨタ
Post by BOBLOOK » Sat Aug 22, 2015 7:03 pm
Msd al the way
After you install turbo you lock the dizzy :ugeek:
Post by Heiska » Thu Aug 27, 2015 10:21 am
BOBLOOK wrote:Msd al the way
Why not COP? Im planning to use yaris (1nz-fe) coils on mine.
Post by BOBLOOK » Thu Aug 27, 2015 5:54 pm
Heiska wrote:
Is because they are more tricky to make them work as the ECU trigger those smart coil packs they don't have separate control module.
Even so if you installed them with an crankangle censor how do your gone trigger them ? How do you gone determine the coil charge time and duration dwell ?
Post by Heiska » Fri Aug 28, 2015 6:21 am
MS2 or ms3 :D
Post by BOBLOOK » Sun Aug 30, 2015 7:57 am
Heiska wrote:
MS2 or ms3 :D
Megasguirt ?
Post by Heiska » Wed Sep 02, 2015 3:07 pm
BOBLOOK wrote:
Heiska wrote:
MS2 or ms3 :D
Megasguirt ?
Yep
hemilove
Post by hemilove » Tue Sep 08, 2015 10:40 pm
But they would work on a waste spark system same trigger point right
