Weber Carb question
TE27007
Weber Carb question
Post by TE27007 »
Just bought a new weber carburetor to replace my stock carb. Can anyone clarify what these numbers really mean? thanks
primary main jet 120, secondary main jet 135, accelerator pump jet 50, primary emulsion tube f50, secondary emulsion tube f6, primary air corrector jet 210, secondary air corrector jet 190 primary ide jet 45, secondary idle jet 50
Re: Weber Carb question
baldo
Post by baldo »
How do you know what parts you have and not know what they mean? You pretty much saying what they are. :lol: So think of the carb as having two sides or function. So this is a 32/36. The 32 will be your primary and 36 your secondary. When you are driving the main one you will be using is the primary. The secondary opens at higher RPM. I would switch the air jets. By "rule of thumb" You need like 50 more than the gas. So 120 gas 170 air. If you put 120 gas and 210 air I think you will have a problem.
