3tc adapter for a tremec t5 trans
bigkahuna
Post by bigkahuna » Mon Sep 05, 2016 11:14 pm
Does anyone know if there is such a thing?
For the price I rather use the tremec than a Toyota trans . Plus you can change all the gear ratios in the trans to suit what you need
D
Re: 3tc adapter for a tremec t5 trans
Post by BOBLOOK » Wed Sep 07, 2016 5:56 am
Am sure with the proper bell housing adapter it will work , 13b to tremec is possible as so 3TC
bigkahuna
Post by bigkahuna » Fri Sep 09, 2016 5:30 am
BOBLOOK wrote:Am sure with the proper bell housing adapter it will work , 13b to tremec is possible as so 3TC
man i been looking and asking people but no one knows.. or wants to share their knowledge ;)
Post by BOBLOOK » Fri Sep 09, 2016 7:16 pm
Well for what i now they use those W50 and W58. The W50 they use to install the jerico internals to make it even stronger.
After those blew the swap to clutch assistance transmissions or clutchless.
tavirace
Post by tavirace » Tue Sep 13, 2016 11:54 pm
Check with G-force transmissions.They have a plate and machine a input shaft for a T-5 transmission
Eville140
Post by Eville140 » Fri Oct 28, 2016 1:47 am
Grab a chuck of aluminum and start drilling holes.
jimijames
Post by jimijames » Fri Aug 09, 2019 3:38 pm
Did you have to machine the input shaft down for the pilot bearing or what did you do for the pilot bearing?
Post by BOBLOOK » Fri Aug 09, 2019 9:07 pm
Machine an spigot bearing
hemilove
Post by hemilove » Wed Jan 15, 2020 6:24 am
Is that a tremek t5
