AE86 camber plates on TE51
Welcome to 3TCgarage Forum the Toyota enthusiast community.
Here you can post info, Report bugs, regarding to the forum. If you encounter registering issue read the related topics.
Toytuner
Post by Toytuner » Sat Nov 11, 2017 3:49 am
Hey guys a friend of linen has some brand new camber plates for an AE86 that he'll give me if they fit. Anyone know if they interchange?
AE25
Moderator
Re: AE86 camber plates on TE51
Post by AE25 » Tue Nov 14, 2017 6:25 am
they are not a direct bolt in due to the bolt pattern difference. ae86 have an unequal bolt spacing of the 3 chassis bolts compared to the equal spaced E3/E5 mounting. so you'll have to re drill the strut tower to make it work. The E2/E3/E5/E7 damper will fit ae86 camber plate.
Toytuner
Post by Toytuner » Sun Nov 19, 2017 5:17 am
Are there any TE51 camber plates out there? Picked up an AE86 GTS rear diff from the junkyard for 50 bucks! The suspension was all gone as were the front brakes.
AE25
Moderator
Post by AE25 » Tue Nov 21, 2017 11:31 am
Shouldnt be too hard to find. For instance the e3/e5/e6 was built on the same chassis. But please confirm before buying...
https://technotoytuning.com/toyota/te37 ... ber-plates
