Post by Heiska » Sun Oct 18, 2015 12:16 pm
Going to paint it when the rack and pinion is on place.
Toyota didnt sell me orginal 3tgteu one so have to make it from and old 2t dizzy.
Post by Heiska » Sat Oct 24, 2015 10:14 am
Post by Heiska » Fri Nov 06, 2015 6:25 pm
Got my "dizzy" back.
Post by BOBLOOK » Tue Nov 10, 2015 10:27 am
waste spark ?
Post by Heiska » Tue Nov 10, 2015 9:37 pm
BOBLOOK wrote:waste spark ?
Yep.
Post by Heiska » Sat Dec 12, 2015 10:45 am
This isn,t going too good :x
This is with new cheap main bearings. So measured the caps, 4 of those cos the machine was too small for measure the 3. cap.
1= 62.012
2= 62.032
3=?
4=62.041
5=62.037
and crank was:
1= 57.965
2=57.970
3= 57.970
4=57.970
5=57.960
IF the bearings are 2mm there is 0.077 oil clearance in 5. I ordered std king bearings and try with those, lets see how it goes. :roll:
Post by BOBLOOK » Mon Dec 14, 2015 7:06 pm
Wow oldschool haven't see those measurement method for almost 20 years :lol: :lol: Are you cutting the crank down ?
Post by Heiska » Thu Dec 17, 2015 3:55 pm
BOBLOOK wrote:Wow oldschool haven't see those measurement method for almost 20 years :lol: :lol: Are you cutting the crank down ?
Good measure method :D No, i dont cut crank. I ordered better quality bearing and installed those.
Post by BOBLOOK » Mon Dec 21, 2015 7:40 pm
Oh okay good luck with the build
Post by Heiska » Mon Apr 04, 2016 4:20 pm
Has been while :D
Just boughted nissan 200 sx front end, few pics of them compared to te71
te71 bush is 12mm hole and nissan is 14mm
Controll arm bolts are: te71 10mm, nissan 12mm
+bigger brakes
+better bearing
+No ae86 prices :D
+same bolt pattern
Nissan crossmember is also quite similar only 0,5cm differense on the bolt holes.
